TwinTurbo.NET: Nissan 300ZX forum - Better off to use regular nuts with lock washers
ZXoltan
on July 01, 2019 at 1:40 PM
I went to HomeDepot and got 8.8 M10-1.5x45mm zinc >>>>
posted by JULIAN
on June 29, 2019 at 05:22 PM
Often times copper nuts are used so they dont fuse to the bolts, but use of anti-seize should be just as good.
Bolts for Test-Pipes >>>>>>>
JULIAN
13:20:29 06/27/19
Will be fine, iirc 10mm or 3/8" will work. (n/m)
itsa300zx
15:12:47 06/27/19
I usually pick up hardened exhaust bolts from an auto parts
ConVerTT
15:16:57 06/27/19
This. (n/m)
MixManMash
16:46:47 06/27/19
Re: I usually pick up hardened exhaust bolts from an auto parts
draker24
21:46:22 07/03/19
Re: Bolts for Test-Pipes >>>>>>>
Rob260
01:45:12 06/28/19
JULIAN
17:22:24 06/29/19
Re: I went to HomeDepot and got 8.8 M10-1.5x45mm zinc >>>>
Rob260
20:41:17 06/29/19
Agreed (n/m)
ConVerTT
15:25:51 06/30/19
Fail (n/m)
ConVerTT
15:25:27 06/30/19
Better off to use regular nuts with lock washers -
ZXoltan
13:40:50 07/01/19
Typically you dont use spring lock washers on exhaust. The
23:08:24 07/01/19
Thanks everyone !!!
JULIAN
16:31:37 06/28/19
